Thanks in advance
Hi-Lift Jack
- ScottishPinz
Hi-Lift Jack
Just got a hi-lift for my birthday, wondering where you can jack a pinz, guessing the front bumper is fine, probably need the adapter for tubular bumpers for the rear. Any advise or tips welcome... anyone used one as a hand winch etc.
Thanks in advance
Thanks in advance
I could be wrong, but I don't think a hi-lift jack is the way to raise a Pinzgauer. Use a floor jack under the differential or axle, and support with good jack stands. I don't trust lifting that much weight by the bumper, and stability might be in question because of the height you would have to raise the vehicle to. I am only talking about tire changing.
- ScottishPinz
We use the Hi-Lift jacks on occassion when on the trails. They have been used to stabalize a truck when putting a tire back on the rim and to lift the trucks when in the sand dunes and of course the most popular to help the jeep crowd out of trouble. I have not used the Hi-Lift as a winch with the pinz though it was a common practice when I had a jeep. The only time I have used it on the pinz when at the house was to lift the body to put stands under it. I still think the Hi-lift is a very useful tool offroad when used properly.
I have mine mounted to the front where the antenna tubes bolt on. If you have the 48" Hi-Lift, you will need to get the 60". The 48" lift just does not work on the Pinz.
My 2cents
My 2cents
I've got a high lift jack, but I must say I've never used it in anger at least on the Pinny.
While I do carry an array of recovery gear and tools in/on the Pinny, it's usually unpacked to recover the other types of vehicles that accompany us on our trips
I have used the high lift to jack up the rear of a Hilux that dissapeared down a hole, so we could put some "stuff" under the wheels.........However another time when the front left wheel of "a different" Hilux dissapeared in a deep rut and the corresponding / diagonal rear right wheel came off the ground we found a VERY LARGE man/bystander
standing on the tailgate did the same job
http://www.ozpinz.com
- ScottishPinz
- ScottishPinz
pinzwheeling
I've jacked mine
under the rear tube bumper multiple times with no issue. I have a Expedition Imports front bumper that holds the Pinz up just fine, I'm not sure about the bumperettes strength.
Pinzinator and a couple of others raise a good point regarding stability. I have a stand that attatches to the bottom of the high-lift to make it more stable. However, nothing will be more stable than a good floor jack, or if changing the tire on flat ground, a decent bottle jack.
The main thing that the high-lift gives you is the flexibility of being able to use it on uneven ground with relative stability, while still being able to raise a vehicle high enough to change the tire.
BEWARE, do not stand directly over or in front of a high-lift handle while lifting or lowering the vehicle. I got a nasty concussion a few years ago when my old high lift wasn't completely engaged, and smacked me so hard in the side of the head I was knocked out in my garage for about 10 minutes.
