limiting straps
limiting straps
Anybody tried the repro limiting straps? They are a lot cheaper but are they as good as the original?
Cory Gray
Cory Gray
limiting straps
Thanks. That doesn't sound good. I guess the originals may be worth the price.
Twin Pinzies
could be shocks or it could be another 710/712 issue. Seems most of the broken straps are on the 712's, which could be we just have more of them also.
If I remember correctly in 3 years I have broken/damaged 5 limiting straps, all factory oem. I am running rancho 9000's. Have not tried repro and will keep replacing with factory unless a good option comes along.
FWIW, I run OEM straps on my 712 and have never broken one. I have, however, broken off several lower shock/strap mounting bolts. (all rears) I did this with stock shocks, and with the NAPA shocks which Dennis recommended earlier. I switched to the Rancho shocks and have broken nothing since then. I don't know if this is reflective of the straps being stronger than the bolts, but at least the strap doesn't seem to be the weak point in the system.
What do the repro's look like? Are they like these?
http://www.okoffroad.com/stuff-susp-limitingstrap.htm
Next time I had a strap break I was just going to throw these on all away around....
Wimps Need Not Apply
limiting straps
I was thinking of getting spares, these look good to carry for that purpose.
What is the stock length of limiting straps for comparison?
Morris
Morris
Mark....you read my mind.
Were you able to get the mount hole to the same size from the manufacturer or will that have to be a backyard special.
Let us know how they fit and post a Pic. Wonder if they come in desert camo?
Miles
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
