Replacing fifth gear?
Has any you heard of the ability to replace fifth gear to achive highway speed? I was told today that they are doing it in California.
- David Dunn
5th in a 710/12 is not a gear but direct drive. With some rework, 4th can be made into an OD gearing. Think of it (gearing wise) shifting from 1st,2nd,3rd to 5th and OD... a long step between 3rd (2.04:1) to 5th (1:1), since 4th (1.30:1) is now a OD gear of some sort.
Hearing this once before, long ago. I would say that the one probably suggesting to do this, is not some one you'd want to work on your Pinz....
- David Dunn
Hi Vince
If it's the same one, they were TD trannies
And their gearing is a lot different than the gassers.
716/18 5 speed
1st 4.25
2nd 2.505
3rd 1.48
4th 1.00
5th .747
710/12
1st 5.33
2nd 3.24
3rd 2.04
4th 1.30
5th 1.00
716/18 5 speed
1st 4.25
2nd 2.505
3rd 1.48
4th 1.00
5th .747
710/12
1st 5.33
2nd 3.24
3rd 2.04
4th 1.30
5th 1.00
First gear @3.636 sounds fine to me. A lot of guys start in 2nd gear @3.24 in the stock tranny.Erik712m wrote:I found a six speed with the following. 3.636 (1st gear), 2.375 (2nd gear), 1.761 (3rd gear), 1.346 (4th gear), 0.971(5th gear), 0.756(6th gear) First gear is 1.694 off the factory gear. How would this affect take off? Would it ruin the clutch?
Is this a common tranny and is it a direct fit?
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
