fan balancing
fan balancing
I am going to have engine work done, is it worth the money to have the fan balanced as well?
Morris
Morris
Pinz Enthusiast
fan balancing
Morris,
Deffinately do it, give Scot at EI a call I asked if he was going to do it and he said he would check into it, I had mine done by Jake Rabey and it works great, but as you can tell from the EFI posts it will take a melinium to get it done, took over 4 1/2 months to get mine back, but it does almost compleatly stop the vibration at the engine, another step is to have the front drive shaft balanced too, Jim L. and I couldnt belive how smooth my truck now runs.
Eric
Anaheim Hills, Ca
1973 712M
1996 LR Disco I
2003 LR Discovery SE
2003 Holiday Rambler Endeavor MH
hope to get a 1969 Ford M656
Anaheim Hills, Ca
1973 712M
1996 LR Disco I
Yes, If Scott doesn't do it. you should be able to get ballanced locally most big air exchanges, towers have there fans ballanced just before install to increase the life of the shaft i had mine done here for around a $100 money well spent. Also driveline ballancing is nice but you better have a competent and honest shop do the ballancing or it well cost you more in the long run. and not just any one can ballance the shaft you have to have yokes made and that isn't cheap close to $700.
fan balancing
Thanks guys, that sounds really positive.
Morris
Morris
MASSIVE PINZ
fan balancing
Thanks Jake,
That is good to know, about the short turn around time. I was going to buy another fan just to avoid the 6 week delay and not being able to drive the pinz.
Morris
Morris
MASSIVE PINZ
I just had my fan balanced for $40 (based on time spent) by a local engine rebuilder and it was done the same day.
It definitely cut down on the amount of vibration I could feel. Now I hope that it will cut down how often I have to retighten the carb screws
Getting the fan off was the only hassle; it did not come off willingly.
Ken A.
Ken A.
