starter removal help
PinzEOD
Post by PinzEOD »
Are parts for a 'bendix only' repair available locally or pretty much a dealer item?
Mike Newton 1973 712M (sold)
Profpinz
Post by Profpinz »
I'm not quite sure what you mean by a "bendix only repair", but the bendix itself is a Bosch factory sealed item.
There is a company here locally that will open the casing, regrinds the roller shaft surface and replaces the rollers for a lot less than a new unit..... I would think someone in the US does the same!
The second time mine played up (about 4 years later, after I did a big boghole) the company said there was not enough material to do it a second time so I had to source a secondhand replacement unit (that's where Dennis came to the rescue).
Like a lot of parts, this Bendix appears to be unique to the Pinny although a few other Bosch units come VERY close in specification....those used on some older Mercedes Benz (1960's, early 1970's) appear, after a brief visual inspection, to be similar, however I haven't looked into it in great detail...... besides some of those are getting as rare as Pinny's :roll:
1997, 718 6X6 Pinzgauer
PinzEOD
Post by PinzEOD »
PinzEOD wrote:Are parts for a 'bendix only' repair available locally or pretty much a dealer item?
I was referring to Jim M's reference to replacing the bendix.
u352
Clicking Starter
Post by u352 »
My starter is clicking and I've tried what I've done with my LR with that starter(hit it) but that didn't work with on the pinz.
Any suggestions.
Profpinz
Post by Profpinz »
Initially I'd check the main power and earth lead to the starter, but it may also be a solenoid problem (the contacts in the end of the solenoid my be crook)
David Dunn
Post by David Dunn »
Could be a bad battery, or low voltage from a charging problem...check voltage too
u352
Post by u352 »
Thanks for the help fellas. I think it was the battery. I separated the batteries and took readings and got 6 volts on one of them and 12+ on the other one. I hooked a starter to the leads where the old battery was and I was able to start the pinz but it was by jumping the starter solenoid. Then I shut it down too far from where I could jump it. So I am getting two new batteries for the truck.
Thanks for the help.
T
Locked
