Squeaky clutch
Locked
I-10pinz
Squeaky clutch
Post by I-10pinz »
So basically the clutch pedal/unit in the cab squeaks when the clutch pedal is depressed and I wasn't able to fix it by spraying WD-40 on the pivot so I'm at a loss and it seems to act up as it gets warmer if that helps, any ideas?
Only from above may they judge my actions below.
Thomas
75pinz
squeaky
Post by 75pinz »
I have had this on several Pinzgauers. The squeaky part on most of them was on the slave itself if I remember right. The ball in the socket thing... Pretty technical i know...
I-10pinz
Post by I-10pinz »
Hmm... ok I think I know what your talking about so is it just a greasing issue or a replacement part job?
Thomas
Profpinz
Post by Profpinz »
Simply remove the clutch slave, grease the ends of the rod between the clutch slave and the clutch fork, and that should fix the problem.... `If that's what it is! :wink:
1997, 718 6X6 Pinzgauer
I-10pinz
Post by I-10pinz »
Ok went out and listend alittle more carefully and yeh it's coming from the slave so hopefully its nothing more than that and is a good excuse to check to fluids too, thanks for the info.
Thomas
Locked
