Hello everybody!
I am getting ready to check my gear oil levels in preparation for an off road trip. I discovered that the manual only has directions for changing the oils, not checking them. How do I check to see if the levels are correct? Do I just top them off? What is the recommended procedure? Start at the front and work back? Where can I expect the greatest problems?
Also do you all check these levels while on a lift or is it realistic to think I can do this on a creeper in the driveway?
What size allen wrench should I use?
Anything else I ought to think about before tearing into this? I know it's GL-4 for the tranny and GL-5 everywhere else.
Thanks!
Timothy
Checking Gear oil levels
LibTimothy
When the only tool in your toolbox is a hammer, every problem starts to look like a nail.
10mm allen wrench, smack the plugs with a hammer, then loosen them with the wrench. I use 10mm socket type with a long ratchet.
Start at one end and work your way back.
If oil is clean, leave it be. Fill till oil comes out the plug hole, on the diffs, remove top and middle plugs, fill from top plug till oil comes out middle plug hole.
Tranny fills from top plug till oil comes out of level check plug (pipe on side of trans.
LibTimothy
Scooter, that is where the love tap with the hammer comes in. You have a couple different types of metal and they tend to bond together over time. A little tap with the hammer and all is good. In some cases can be taken out with just the stock allen wrench and very little force. Change the crush washers regularly and there is not as much need for tightening the plugs so tight they become difficult to get out.
