slowing down up hills
my pinzgauer slows down going up some steep grades on the highway this one hill in particular i speed up to 100km and i almost have to downshift to 4th does anybody have a pinz that doesent slow down going up grades on the highway?
710M 1972
710k 1974
710k 1974
Re: slowing down up hills
You are kidding, right?norcal pinz wrote:my pinzgauer slows down going up some steep grades on the highway this one hill in particular i speed up to 100km and i almost have to downshift to 4th does anybody have a pinz that doesent slow down going up grades on the highway?
Twin Pinzies wrote:You are kidding, right?norcal pinz wrote:my pinzgauer slows down going up some steep grades on the highway this one hill in particular i speed up to 100km and i almost have to downshift to 4th does anybody have a pinz that doesent slow down going up grades on the highway?
I'm sure there is more to this story than what has been written so far.
Down here in FL we don't have hills so I'm not sure what you're talking about.
If you didn't get stuck, you didn't try hard enough.
'74 710K
1984 in 2009
'74 710K
1984 in 2009
Hills?
Some ballast helps get traction... It seems obvious that you're using too much weight. Get rid of your current tires and you won't need as much weight to have decent traction on the steep grades.
Most of us do have problems when the slope exceeds 90 degrees.
Thomas E.
Sonora, CA
Thomas E.
Sonora, CA
The 5th gear in high range is in fact a sort of overdrive. It is not ment to keep your highway speed up to a 100 kmh on a steep highway road when your Pinz is heavily loaded .... etcnorcal pinz wrote:my pinzgauer slows down going up some steep grades on the highway this one hill in particular i speed up to 100km and i almost have to downshift to 4th does anybody have a pinz that doesent slow down going up grades on the highway?
Regards,
Jacques
Your are incorrect, 5th gear is direct drive(input shaft directly coupled to output shaft). Overdrive is built into the 4x4 transfer case gearing, 6x6 cases are geared without.
And to answer the first post, yes, hills will slow down an 87 HP truck.
One solution to improve climbing hills is to bump up the compression and displacement, and install a custom cam to improve torque under load.
Look at the cam specs in the manual, there is much improvement to be made. Hopefully I will get to finish my new engine soon so I can test a new higher HP cam grind.
But before that I have to install my new lightened driveline and rebuilt transfer case
What is the horsepower rating of your 2.7?
Morris
Morris
What is the horsepower rating of your 2.7?javascript:emoticon(':D')
Morris
Morris
- Jimm391730
I'll chime in here too; I got an honest extra gear in power - where before I HAD to downshift, now I don't... before it would take forever to accelerate in 5th (not surprising, with a 7500 lb truck) it actually accelerates like 4th now.My cams are designed to increase torque curve to 4000 rpm and add a noticeable increase in power on hills.
Just ask Ed Olsen (Ramfan) how they perform
Overall around 20HP increase at the rear wheels.
712W with Jim L.'s 2.7, cam, pistons, and EFI
