The past few days, we've had temperatures into the low 30s here in the Houston area. This is extraordinary as winter time temps typically don't dip much below 40 and then for only a couple of hours at that. I used the Pinz for some in-town driving around and couldn't believe how crappy the heater was. I hoped I would warm up after awhile and it just never did.
I was freezing!
Other than proper level placement for heat on/off and or air flow on/off, is ther some trick to generating more heat in my 710M short of installing one of the gas heaters?
Thanks!
