What is the minimum steel thickness would you want on a table you're going to use for welding?
I've started my storage shelves. And putting out the fires between welds on my current wood work bench isn't cutting it.
Welding table Top?
A friend had one that was about a 1/4" thick but they can start to become impractical to move around, depending on how big you need it to be. I think you could do well with a 10 gauge top and that's not too expensive to get from your local steel supplier. You can weld some channel under it if you need to stiffen it up easy enough.
welding table top
I saw a nice one that a friend had that was an angle frame with expanded diamond mesh top and angle legs. Things (bits of metal) that he ground off fell through and it was sturdy enough to hold parts he worked on.
Here are a couple of pictures of the local fabricator’s benches; just some ideas
With the heavy duty wheels they are able to roll them around pretty easily
sold 712AMB/M 2.7L Goatwerks Power! UglyDuck living the life in Alaska
I am pinzless.
I'm at Poway Jeep If you all need a hook up on a Cummins, Hemi, Or a Jeep. PM me.
I am pinzless.
