Muffler Replacement
goudacheese
Muffler Replacement
I need to get a new muffler. While revving the engine it started backfiring and eventually blew the muffler wide open. Swiss army only sells the side pipe muffler and I have the rear pipe. Any ideas?
Your only limitation, is the creativity of your imagination!
goudacheese
Mark, I am going to work on it this weekend. I am going to re-adjust the timing to around 12 degrees and remove the round ballast/resistor and check the wiring as it may be sending full voltage to the coil. I ordered a dual input, single outlet muffler and will have it installed once I fix the backfiring.
