engine won't start
engine won't start
Here goes, Put my civilian kit on a couple of weeks ago and have put 20 to 30 miles on my 712. I tried to start it up after parking it just for about an hour and it didn't want to start. It was turning over but it wouldn't fire up. Pumped the throttle, choked it and still nothing. Set for a minute and started cranking again with no throttle and she finaly busted off. Sounded like it was flooded, cleaned out and revved up. Brought it home and killed it. Can't get it started at all now. Put new plugs in it and still won't start. Is there a resistor or a module somewhere that I need to check? My jeep friends are laughing. I need help.[/i]
Roger Melton
won't start
Jim,I checked that and all plugs throw a big spark. The plugs are wet with gas when I pull them.
Roger Melton
If you have an old 12v coil laying around it would be good to install it for a moment to see if the truck starts. I had an issue with my 712 where it had what looked like great spark and lots of fuel but would not run. Turned out that after getting rid of the flamethrower coil all is better now. BTW I used a bosch blue from a VW store, quick and easy to get. The truck runs great again. Took me some time to get it through my head that since I had spark and fuel the truck should have been running. It is always the simple things that stop these trucks.
won't start
I had an issue with the wire from the radio resistor (that 3 inch long silver tube) one of the wires was so frayed that only two strands of the stranded wire were connected. Took a long time to trace it down but after reattaching it the pinz started fine.
Didn't get much juice through those two little strands. Apparently a lot of off road shaking will mess with connections.
chacaocop1
