air con
air con
Hi fesm-ndt,
Does that mean they have stopped stocking that part?or are they awaiting new stock?its always a bit of a worry when they stop stocking various parts.Have you decided what roof top unit you will use,if you get the bracket,I purchased mine in June @ 332.22 Euro. Hope you get sorted.it does make a big difference .
Regards.
Garymartin.
Regards.
Garymartin.
Re: air con
yep the comment was out of stock and not sure when they will have stock.Garymartin wrote:Hi fesm-ndt,
Regards.
Garymartin.
I was in Perth a few weeks back and spotted a Red Dot in a truck breakers. I am orgainising getting it shipped. It's a 12v one, but well nothings easy..... so will have to:
- change solenoids and fan motors
- mount the pump and the roof bit
I think a January job.....
Regards
(Project Gimpy 2)
(Project Gimpy 2)
No luck thus far..... I did see a small unit the other day. An older steel unit what I would prefer, but guessing will need anything electical changed to 24v.... (may do that on Saturday).Garymartin wrote:Hi fesm_ndt, Have you managed to obtain an air con unit ? sorry no spare mounts here. Have STEC re stocked with bracket? which part of oz are you based.
Regards
Garymartin.
Haven't talked with Stec for awhile but thinking a lot of wrecked Swedish ones out there
I'm from Perth originally
Regards
(Project Gimpy 2)
(Project Gimpy 2)
aircon
Hi Mike, I just found a Swedish hydraulic pump mount in the back of my shed !!
I,m not sure if it's suitable for your aircon compressor but give me a direct e-mail address and I'll send you some pictures so you can decide, I've probably got the shovel mount you're after as well, ( my shed is full of wonderous things
) Cheers Nigel.
Re: aircon
sounds like a good shed. Sent a PMpinzmeister-uk wrote:Hi Mike, I just found a Swedish hydraulic pump mount in the back of my shed !!I,m not sure if it's suitable for your aircon compressor but give me a direct e-mail address and I'll send you some pictures so you can decide, I've probably got the shovel mount you're after as well, ( my shed is full of wonderous things
) Cheers Nigel.
Regards
(Project Gimpy 2)
(Project Gimpy 2)
Received an answer from S Tec and was told it is still no stock. They are going to answer if any more are being manufactured.fesm_ndt wrote: I have contacted Stec today to see if they have any more in stock.
Also a lot of the covers etc are "no longer available" so be careful with your plastic bits
Regards
(Project Gimpy 2)
(Project Gimpy 2)
