My heater fan motor wasn't working as the previous owner had been swimming. Took it apart and things were fairly corroded, although bearings span freely. Greased them up again, cleaned the commutator and resoldered the wires that had come adrift.
However, when I switch it on, it turns very slowly - not sure if this is just because of rust on the stator - suspect there is a short somewhere.
What RPM/wattage of motor could I get to replace this one without having to go original?
Replacement heater motor
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin
Pinzgauer 710K
MegaJolt ignition
blackstack
- totaljoint
don't know, but I'll bet this could be made to work:
http://cgi.ebay.com/JABSCO-3-FLEXMOUNT- ... 439b9b5ca4
