I do not know if there is a distinct "clack" from a solenoid engaging the teeth, but if it is, I did not hear it. But starter was spinning OK.
I proceeded to remove the starter. I removed bottom bolt and noticed that starter is "dancing". Rubber mount broke. I removed the starter. Teeth were dinged and "stop ring" was cracked, had a 1/5th of it blown off. Flywheel teeth were dinged too. I can pull
sprocket out and it will return back under the action of the spring. I am enclosing pictures below. It is obvious that I need to get new mount and either fix or replace a starter. I have following questions:
1. How far does solenoid push sprocket into the flywheel?
2. Some teeth on flywheel appear dinged and cracked (did not turn the whole flywheel to check all teeth). Assuming the damage on the pic shows more or less worst of it, do I have to replace
the flywheel/ringgear too? That would triple the price of a repair
I am afraid.
3. What most likely caused this problem? Did cracking of a rubber mount caused the starter do interfere with a flywheel, or did some unusual interaction between the sprocket and flywheel caused cracking of a rubber mount?
4. What would be the the best way to extract small pieces still
present in the flywheel housing. Obviously if ringgear needs to be replaced, this is the last thing I need to worry about.
Your comments are appreciated. Please give a good tug (up down left right) to your starter before next drive. Pics below are thumbnails, click for full size pic.
OG
