Filling the tranny will oil
Jerbearyukon
Is it just me or am I missing something. I find the manuals pretty hard to follow to find the basic things.
Case in point. The tranny needs fluid change and I can see the one for draining but I am having a hardtime locating the filler plug.
A PICTURE would be great.
Also I was wondering if I did this right. I filled the portal hubs toady with (85-145wt) and I drained it and then just filled the top plug until it ran out (is that correct).
did the diffs and the back gearbox (80-90wt) that the driveshaft goes to from the tranny....same proceedure (hope I did it right).
Thanks a bunch.
jerbear
Thanks a bunch.
jerbear
blackstack
Heres a picture. It is the last one in the set
http://www.flickr.com/photos/agingman/s ... 886723729/
I use a regular wrench to take the fill plug off
Jerbearyukon
blackstack
My picture should get you there...maybe you dont have the nut...i dont know if it is standard or the last guy did a modification, EI has the nuts if you want to make the change. I know i did not have to remove any floorboard...this link is direct
http://www.flickr.com/photos/agingman/5 ... 886723729/
If you blow the pic up you can see that the standard plug screws into the nut.
Jerbearyukon
blackstack
Yes...when you take it off it will be obvious the picture on
page 107 of the operating manual shows the nut (fig. 87/1) so it appears it is the stock arrangement.
Twin Pinzies
blackstack
Jerbearyukon
Jerbearyukon
