First I'm back from a long trip and on my way back it was like being in a carwash. :shock : It pouring so bad that at some point the fan belt was slipping on the pulley.
I made it almost home without a problem but maybe 5 miles before home it started to misfire and I barely made home. It finally stalls right in front of the driveway. Lucky me.
Now, yesterday I took apart the ignition system and cleaned everything in there. There was some humidity inside the cap but nothing to bad. I put everything back together and went for a test drive. Idle was good but when it reaches 3500 rpm no more power. I came back home and decide to check it back this morning.
This morning the truck is not starting at all. It cranks fine and I have no spark at the plugs. I checked everything and I have 12 volts before the noise suppressor before cranking and 24 volts when cranking. I checked my coil and first and second stage are in the spec but still no sparks.
I did switch coil and pertonix ignitor and nothing is working. I'm cleuless.
Please give suggestions and help. It's like I'm getting nowhere here. It is the first time I'm having such a hard time with a Pinz.
Denis
