Blinking Speedometer Light
jrcotner
Post by jrcotner »
I noticed that the light on my speedometer was blinking so I fished around to make sure all of the wires and grounds were well connected. I found they were, and further noticed that the blinking was speed dependent. And when I came to a stop the light was either on or off, but with a little roll it would blink the other way. Any ideas on where this is originating?
John Cotner
New Ulm, MN
Re: Blinking Speedometer Light
Its grounding through the speedo chassis and cable. Make sure the ground wire has a solid ground
Post by stiffler4444 »
ya, that's all about grounding.....I have lazily ignored mine and between the speedo and the gas guage, it's like a disco at night...... :lol:
Stekay
Post by Stekay »
This sheds light on how sensitive a good ground is to voltage drop.
http://www.aeroelectric.com/articles/grnding.pdf
'76 710K
jrcotner
Post by jrcotner »
I'll re-check the grounds and clean them up.
John Cotner
New Ulm, MN
John L
Post by John L »
Jr
I had this issue and the problem was the bulb wasn't locked in properly. It would make connection and work and then lose it and go dark. I'm all about checking easy first. Pull the bulb connection out and check it. The bulb has to be pushed in and twisted. Hope this works.
John L
