air correction jets..
so i've been rebuilding my carbs.... first one was missing one of the air correction jets, no big deal. I ordered a set of two from expedition imports with the only part # I could find in the manual. when I got them, they were labeled 210. the original is labeled 230, I replaced them both. Now, I get to the second carb and they are both 230 as well. will the 210's make a big enough difference that I should try and find the 230's elsewhere? also if anyone has a part # on those I'd appreciate it. I need to order a piston pump anyway, as the one in my second carb was in pieces.
...and now the fun part.
1981 712 amb
1981 712 amb
- westernair
Re: air correction jets..
Yes they need to be the same. If you dont want to rereplace your new ones you just ordered go to a buy a set of jet files or go to race engine builer and see if they have a set you can borrow. They are about $15 for an econo set.
I like to "fine tune" my VW carbs with files.
a pair of 210's can easly be opened up to to 230
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
Mine have got 200's fitted, wondering whether I should open them up a bit to help with my rich running problem?
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin
Pinzgauer 710K
MegaJolt ignition
