strange socket ?
norcal pinz
strange socket ?
today i noticed a small socket a little smaller than a cigarette car lighter i was wondering if somebody knows what it was used for ? it is mounted on top of the intake cowl right next to where the bolts for the front nameplates are there is also one to the left of the steering wheel ?
710M 1972
710k 1974
710k 1974
- McCall Pinz
I'm not sure about the one on the front, but if it matches the one on the side of the steering wheel, then that is an electrical socket like a cigarette lighter but a different size. EI and SAV sell the correct size plug-in so you can actually use it and plug stuff into it. 24v of course. There are two different size original worklights that I've seen fit it.
Re:
Is this the plug?McCall Pinz wrote:I'm not sure about the one on the front, but if it matches the one on the side of the steering wheel, then that is an electrical socket like a cigarette lighter but a different size. EI and SAV sell the correct size plug-in so you can actually use it and plug stuff into it. 24v of course. There are two different size original worklights that I've seen fit it.
- audiocontr
Re: strange socket ?
yup
Norcal pinz,
I use that one to tap off for my AC.
http://s400.photobucket.com/albums/pp88 ... MG3343.jpg
Just above Elmo
Just above Elmo
- David Dunn
This is a 3+ year old thread... I think he knows the answer by now...
I didn't!!David Dunn wrote:This is a 3+ year old thread... I think he knows the answer by now...
- David Dunn
You should have, I told you about them in the other thread.berger wrote:I didn't!!David Dunn wrote:This is a 3+ year old thread... I think he knows the answer by now......and I plan on using it for my Garmin 60Cx.
I guess I was mixing up the two plugs...the one behind the passenger and this one....David Dunn wrote:You should have, I told you about them in the other thread.berger wrote:I didn't!!David Dunn wrote:This is a 3+ year old thread... I think he knows the answer by now......and I plan on using it for my Garmin 60Cx.
