strange socket ?
norcal pinz
strange socket ?
Post by norcal pinz »
today i noticed a small socket a little smaller than a cigarette car lighter i was wondering if somebody knows what it was used for ? it is mounted on top of the intake cowl right next to where the bolts for the front nameplates are there is also one to the left of the steering wheel ?
710M 1972
710k 1974
McCall Pinz
Post by McCall Pinz »
I'm not sure about the one on the front, but if it matches the one on the side of the steering wheel, then that is an electrical socket like a cigarette lighter but a different size. EI and SAV sell the correct size plug-in so you can actually use it and plug stuff into it. 24v of course. There are two different size original worklights that I've seen fit it.
Post by Jim LaGuardia »
The socket on the cowl is for the blackout light, it uses the same accessory plug as the socket to the left of the flasher :wink:
Cheers, Jim LaGuardia
"Arch Magus of Machines."
Re:
McCall Pinz wrote:I'm not sure about the one on the front, but if it matches the one on the side of the steering wheel, then that is an electrical socket like a cigarette lighter but a different size. EI and SAV sell the correct size plug-in so you can actually use it and plug stuff into it. 24v of course. There are two different size original worklights that I've seen fit it.
Is this the plug?
Re: strange socket ?
yup
Norcal pinz,
I use that one to tap off for my AC.
http://s400.photobucket.com/albums/pp88 ... MG3343.jpg
Just above Elmo
David Dunn
Post by David Dunn »
This is a 3+ year old thread... I think he knows the answer by now...
David Dunn wrote:This is a 3+ year old thread... I think he knows the answer by now...
I didn't!! :mrgreen: ...and I plan on using it for my Garmin 60Cx.
David Dunn
You should have, I told you about them in the other thread. :| :P
I guess I was mixing up the two plugs...the one behind the passenger and this one.... :oops:
