Transfer cased just popped out of Hi range into neutral and
David Dunn
Re: Transfer cased just popped out of Hi range into neutral
Post by David Dunn »
Jer
I would still think that the ball and socket were stiff and didn't pivot correctly... unlike a body part, that cable wouldn't shrink in the cold :wink: :lol:
Jerbearyukon
Post by Jerbearyukon »
Hey I am not giving up on her.....it was the plan anway..I have her rigged up for the north but in costa rica I will die in there without AC. Be nice in that country to be ablw=e to take the roof off to and get the fresh air.
Dave...the socket was moving pretty easily so maybe it was something else.....I have been running it disconnected for a whole day all over the place and nothing nada....
I will try the cable tomorrow and check the length out and if its not bang on then I will just lengthen it.
Jer
David Dunn
Jer
If you want a softtop, just remove the hardtop on your K... that's what I did on my 716. Not a tough thing on a 710 and Scott makes tops for them. Even a standard 710M top will fit... just can't use the rear side doors when the top's down. I liked the front facing rear passenger's seats
Jerbearyukon
hmmm...maybe that's the way to go....we will see
thanks
Jer
crcpinz
Post by crcpinz »
It's only $400 for a new one:
http://www.pinzgauer.com/showdetails.ph ... 101243210/
I rebuilt mine for $150.
Glad it's the cable.
Si vis pacem, para bellum
1976 710K
David Dunn
Unless the cable end is bad or frayed, he won't need a cable, just an adjustment
crcpinz
Post by crcpinz »
Yes, sorry, rereading I understand now that Jerry meant the transfer case and not the shift cable when he stated $1200 or so for the rebuild.
1976 710K
