Seat Belt Re-inforcements
ExpeditionImports
Post by ExpeditionImports »
Hi Guys,
Pictured is an additional option for seatbelt re-inforcements. Takes a little work but defintely adds rigidity to the A-track mounting.
Scott
718 HLH Fabrication (32)SM6.jpg (83.6 KiB) Viewed 3835 times
718 HLH Fabrication (20)SM4.jpg (83.79 KiB) Viewed 3835 times
Vallejo, California
www.expedition-imports.com
Tibbermore
Re: Seat Belt Re-inforcements
Post by Tibbermore »
Looks like a neat job. What size metal strap did you use for the reinforcing bars? Is the E-Trac welded to the bars or just bolted on? Is the bottom edge of the lower bar lined up with the base of the side rail; I saw some posts indicating it is better to keep the E-Trac up a little to allow the seats to clear when folding over - is this an issue? Thanks
ExpeditionImports
It's actually L-channel for rigidity. 1.5" x 1.5" Once the channel is welded to the rails we use a really high tech method to drill it every 6" for the M6 Nuts and Bolts to bolt the A track to the channel. :)
The bottom of the E-track is high enough up the rail to clear the folding seats with belts installed. (About 2".5")
Scott
718 HLH Fabrication (6)SM2.jpg (89.81 KiB) Viewed 3786 times
Vallejo, California
Roverchef
Germany
Post by Roverchef »
Too bad it's not the 4x4 mobile-workbench version...Great outta-box think'n Scott!
