Hi Guys,
Pictured is an additional option for seatbelt re-inforcements. Takes a little work but defintely adds rigidity to the A-track mounting.
Scott
Seat Belt Re-inforcements
ExpeditionImports
- DSC_0137SM7.jpg (85.02 KiB) Viewed 3829 times
- 718 HLH Fabrication (32)SM6.jpg (83.6 KiB) Viewed 3829 times
- 718 HLH Fabrication (20)SM4.jpg (83.79 KiB) Viewed 3829 times
Vallejo, California
www.expedition-imports.com
Vallejo, California
Tibbermore
Re: Seat Belt Re-inforcements
Looks like a neat job. What size metal strap did you use for the reinforcing bars? Is the E-Trac welded to the bars or just bolted on? Is the bottom edge of the lower bar lined up with the base of the side rail; I saw some posts indicating it is better to keep the E-Trac up a little to allow the seats to clear when folding over - is this an issue? Thanks
ExpeditionImports
It's actually L-channel for rigidity. 1.5" x 1.5" Once the channel is welded to the rails we use a really high tech method to drill it every 6" for the M6 Nuts and Bolts to bolt the A track to the channel.
The bottom of the E-track is high enough up the rail to clear the folding seats with belts installed. (About 2".5")
Scott
Scott
- IMG_0488.JPG (47.09 KiB) Viewed 3780 times
- IMG_0487.JPG (52.08 KiB) Viewed 3780 times
- 718 HLH Fabrication (6)SM2.jpg (89.81 KiB) Viewed 3780 times
Vallejo, California
Vallejo, California
Too bad it's not the 4x4 mobile-workbench version...Great outta-box think'n Scott!
