When I turn on the ignition key the 4500 dash indicator flashes once which is supposed to indicate that the rpm module is working.
I drove it multiple times with the same results - the longer the drive, the hotter the resistor. The truck runs and drives great.
So, what's anyone suggest as my diagnostic path?
I was going to jumper the 2 center pins on the rev limiter plug (thanks Jim L.) but assuming this fixes it I'm not sure if this tells me the rev limiter is bad or the resistor is bad.
Or should I start by measuring voltage at the coil?
Thoughts, comments, suggestions are appreciated!
