LED Headlights
compunerdy
LED Headlights
Post by compunerdy »
Anyone try some of these? Says they will fit the Pinz..
http://www.ebay.com/itm/PAIR-OF-BRAND-N ... 15&vxp=mtr
Tim
1975 710K
Re: LED Headlights
Re: LED Headlights
I have them on mine. They fit nice and are a very bright, white light.
That's a decent price too.
Re: LED Headlights
These are the newest Truck-Lite LED lights
Truck-Lite 27270C 7" Round LED Headlight Review and Demo:
https://www.youtube.com/watch?v=2q9NfJdmtdE
This video compairs the old, new Truck-Lite 7" LED's and then JW Speaker 7" 8070
27270C Photo:
Re: LED Headlights
Interesting video with a very good demo of both Truck-Lite models.
Being the gadget nut that I am, I have both of the Truck-Lite models - the older style 27250C in the photo above and the newer style 27270C on my other 710M (sorry, no photo).
Personal opinions follow:
-the newer model does have a brighter, wider beam pattern. This can be good or bad depending on your usage. I find they are a bit too wide and bright for typical highway use. Careful aiming is critical. Off-road they are fantastic.
-the older model is fine for the highway though again careful aiming is important. I find them great for off-road use.
-I prefer the look of the older model, others disagree.
-I definitely prefer the price of the older model, approx. $250/pair on ebay, etc. versus approx. $240 each for the new model. Occasionally the new model shows up on ebay at a much better price.
I guess it really boils down to how much money you're willing to spend. Either way you go these lights are a tremendous improvement over anything else I've tried.
Re: LED Headlights
Thanks Paul - I am in the middle of thinking about 20 different projects for the new Pinz and am going crazy with Google research :)
Your review is extremely helpful!
Re: LED Headlights
Hi Dan,
Glad I could help. There's nothing I like better than a new project and the Pinz always beckons me. I've got to be careful to not add more than necessary though :wink:
compunerdy
Re: LED Headlights
These look like the old style but with military plugs?
http://www.ebay.com/itm/NEW-MILITARY-TR ... e3&vxp=mtr
$225 shipped
Tim
1975 710K
Re: LED Headlights
The old style were made for the military and I've only seen them with those style plugs. It's easy enough to find the compatible plugs or just remove them and install what ever you prefer.
One note: The original/old style Truck-Lites do not necessarily have the DOT embossment on the lens so if you're in an area where the truck has to be inspected keep this in mind.
Re: LED Headlights
I bought the last type listed in this thread; the free shipping is nice. I took the actual LED lens module from the green housing; the module has ~6" leads with bullet connectors that plug into the inside of the housing connectors, so they just unplug. Then I used a mating bullet connector on the end of the Pinz headlight wire(s) and plugged them right in.
If I remember correctly, there is a white, blue, and red lead; white goes to ground, blue is high beam, and red is low beam. The original headlight ring clamps it in place into the Pinz headlight bucket exactly the same as did the stock glass reflector/lens.
My opinion is that they make slightly less light than the 70/75W halogen bulbs that I had been using but the LEDs focus the light more accurately so they end result is that you get more light where you need it; but the light that is missing that wasn't doing much good was missed, inititially, until I got used to the beam pattern of the LEDs. Overall the LEDs are at least as good if not better. I may not have sprung for them except I had a headlight out already so rather than going back to non-halogen bulbs (which I can't get anymore) I decided to do the LEDs.
mopar
Re: LED Headlights
Post by mopar »
I have pictures of the low and high beams posted. Light is very good nice and white. Here is what they look like on my pinz.
1974 712M AKA the Banana
1987 718M Now Sold
1975 Volvo TGB1111 Now Sold
1963 404S Now Sold
sixbennetts
Re: LED Headlights
Post by sixbennetts »
Buy the set on Ebay that comes with the housing. Remove the bulbs and replace your stock headlights, THEN, put your old headlights in the empty housings and mount them as auxiliary lights!
I am SUCH a cheap Yankee.
Re: LED Headlights
This is good review of many types of headlight replacements (long but worth it)
Ignore the J**P it uses exact same headlight :D
http://www.pirate4x4.com/tech/usmcdoc/lights/index.php
sixbennetts
Re: LED Headlights
What's the headlight pinout on the Volvo? What color wire is what?
Re: LED Headlights
sixbennetts wrote:What's the headlight pinout on the Volvo? What color wire is what?
Sorry I can't help
Perhaps wrong section - not sure if Volvo owners go through all the Pinz stuff?
