Front axle boot replacement quick quesitons.
radmanrugg
OK I am about to replace my front axle boot with a solid boot. I have the pinz spring compressors and the axle press off tool. Just some quick questions.
Can I remove the stearing arm directly off the hub by the 3 attaching bolt and or nuts? That should allow me to put it back together without any adjustment to stearing. Will oil leak out of the hub (should I drain it first)?
Current action plan:
1. Block back tires and jack it up via differential housing and insert jack stand at a height the opposite tire can barely touch the ground to compensate for weight removed from the work side.
2. remove tire and place nuts to keep brake in place
3. remove tie rod by 3 attaching bolts/nuts.
4. pinch off brake line with hose clamp and remove from hub.
5. compress spring until removable.
6. remove over limit strap and shock (inspect for wear).
7. attach axle press off tool. Measure / mark where things are located for reference in reassembly.
8. work the chisel into the split to relieve clamping force keeping the halfs together.
9. remove the current boot clamps
10. work the axle half off with the press off tool and set aside checking condition of o-ring. (care not to drop)
11. work old boot off cleaning things as needed.
12. put on new boot with a good silicon sealant on connection surfaces and clamp in place.
13. fit things back together in reverse
14. bleed brakes.
Possible gotchas:
oil leaks
worn o-ring
worn or damaged ring boot attaches to
bolts not wanting to come out (kroil + heat + possibly have to drill out)
spring bomb
Anything I am missing?
Scott
PS: I wish the forum had stickies for peoples write ups. Searching is difficult when you use common words like axle boot.
14. bleed brakes.
Possible gotchas:
oil leaks
worn o-ring
spring bomb
Scott
Re: Front axle boot replacement quick quesitons.
Use bookmarks to save all your 'favorite' posts
Bookmark Topic
Then you can just click bookmarks and fins them all in one place!
Bookmark Topic
If it were me I would not pinch a brake line. I not want to risk damaging the line. It could likely stand blessing anyway.
Radmanrugg,
I'll quote and reply.
6.5 Remove axle clamp nut/bolts and centering bolt. All three must be removed!
I like to assemble the boot with loctite, and allow it to dry, before attempting to slide it onto the stub axle. Otherwise, it's hard to get it to stay together. If it splits, I seal it with RTV.
Pinching the line carefully is likely okay, but otherwise it's an opportunity to flush the line/s. If the lines are old and brittle, it might be wise to replace them regardless.
So long as the opposite is off the ground, the weight you remove will only lift the side you remove further. Good to go.1. Block back tires and jack it up via differential housing and insert jack stand at a height the opposite tire can barely touch the ground to compensate for weight removed from the work side.
I actually remove the drum to reduce weight.2. remove tire and place nuts to keep brake in place
You don't necessarily gain by complete removal of the tie rod. I'd just pop the outer connection.3. remove tie rod by 3 attaching bolts/nuts.
VERY IMPORTANT. Only compress it as far as the manual allows. IIRC, like 10 1/2", but that's from memory. CHECK!! You can damage the spring otherwise.5. compress spring until removable.
At least one end of each.6. remove over limit strap and shock
No. Centering bolt locates wheel drive into stub axle.Measure / mark where things are located for reference in reassembly.
You're this far. Buy a new o-ring and replace the dam* thing now.checking condition of o-ring.
ccalingaert
Ed - I think anyone who has survived a panic stop in a pinz is still praying for better brakes. What is the appropriate prayer?edzz wrote: It could likely stand blessing anyway.
Chris
'74 710K
'74 710K
ccalingaert wrote:Ed - I think anyone who has survived a panic stop in a pinz is still praying for better brakes. What is the appropriate prayer?edzz wrote: It could likely stand blessing anyway.
I was actually thinking bleeding the brakes would be a good idea however blessing them probably is a good idea too.
I really must remember to poof read what my phone comes up wuth.
"Our Lady of Prodigious Deceleration, don't fail us now."What is the appropriate prayer?
It works quite well, so long as your brakes are correctly adjusted.
Does anyone have a manual in front of them? I have my springs in the car, going to get them banded today. Don't want to mess up the springs......
If not, I'll reference the manual tonight....
Page 4 of the BODY Section:stiffler4444 wrote:VERY IMPORTANT. Only compress it as far as the manual allows. IIRC, like 10 1/2", but that's from memory. CHECK!! You can damage the spring otherwise.5. compress spring until removable.
This may help too:
Here you go: 280 mm = 11 in
- Front Spring.jpg (73.71 KiB) Viewed 6135 times
Excellent thanks!
