Intro from Malaysia - WR7002 - C304
geckoadventure
New Zealand
Re: Intro from Malaysia - WR7002 - C304
Post by geckoadventure »
The builder off to the rainforest challenge (RFC2013) tonight so I got a quick update and worse the worker doing all the welding resigned.
Dash is built and console - overhead console not done but all gauges will be up on the console except the speedo (Garmin colorado GPS) and the tacho - tiny tach.
So work has stopped for 2 weeks until the 15th at least. My goal is just after Feb - ideally for my birthday on 5th March I want it on the road.
Once the dash is built and the overhead console done its sand blasting and painting time.
geckoadventure
New Zealand
The to do list to get to 1 March 2013 completion date
01. Order Tiny Tacho
02. Buy Garmin Colorado
03. Order Digital Fuel Gauge from US
04. Order Air and Vaccumm gauges
05. Design Overhead Console
06. Build Overhead console
07. Position for Inverters and USB chargers
08. Design Rear Side bars and access to replaced removeable doors
09. Wiring
10. Sandblast and undercoat and paint chassis and body
11. Fit Alloy body panels
12. REfit every part.
13. Sound proofing fit (after back in Kuala Lumpur)
14. Collect shcks from Malacca
15. Buy leaf springs (after back in Kuala Lumpur)
16. Power STeering do (Ford F5000 tractor kit)
17. Buy 3+3 seats for rear $600rm each) and harnesses
18. Fit rear seats
19. Tie Down points identify and fit/create
20. Hammock connect points fit
21. 100liter Water Tank Make (Anivsah to supply 3 filters)
22. Roller slides purchase 4 - delivery January from Australia
23. Buy 4 MAxxis Bighorn 762's
24. Buy 200' of 11mm winch wire for the PTO and 125' of 9mm for the M12000 winch
25. Design PTO winch lock (Lever by vaccum) to replace canvas strap
26. Oil leak in DIFFS fix
27. Electric pump for engine radiator
28. REplace CV booties
29. Buy 2 200 amp batteries
30. Buy Reversing camera
31. Buy Icom VHF radio speaker
32. Buy driving camera.
geckoadventure wrote: 32. Buy driving camera.
Is that so you can drive while windshield is covered in mud ?
:mrgreen:
Green Crocodile
Post by Green Crocodile »
I think this is the wish list to Santa! ))
Still playing in the mud
geckoadventure
New Zealand
Long (5 hour+) visit to the workshop on Boxing Day since the mechanic was working on the truck XMAS day I had no issue having a vist. Arrived 11.3am time for chit chat and then lunch and then the serious stuff. First the office we started with a blank sheet for the control panel and worked our way through switched 1-26 which need to be on the control panel
Then the discussion on 12v vs 24v everthing discussed and reviewed again.
The empty switch box ready for me to reach when harnessed in.
Slowly the switch location emerged till we had this on the full size drawing.
The wiring diagram revisited all red is 24v all blue is 12v.
After 60+ minute time to go to downstairs and discuss Bretts list then mine.
Inside the console is also the fuse panels all at an angle I can see and reaach easily. A lift up hatch will make for easy access.
Whats been done - all the ALLOY panels are cut out and now waiting for the rear seats and Drawer system to be installed.
There will be a raised platform at front 1/2 of the rear to sit fridge on (no it will not slide) and underneath will be a sliding table to be used as a cooking bench it will slide out approximately 600-800mm and will be 39" wide (1 meter).
The exhaust is now in place along with the hilift jack (6ft) and the shovel and chungko will also go here. The air intake will also fit up beside the exhaust.
I now have the depth of the fuel tank the matching gauge and sender from VDO can be ordered.
Then onto the rear seats 6 of these to be fitted they are 22" wide each we have 68.5" to fit them in. See our wonderful crash test dummy not smiling as we get the seat height correct. Once fitted then we can strip the rear sandblast it and undercoat it for the panels to be fitted. The seats are to only be fitted when the doors are removed and fixable sides designed along with harness seatbelts. So it will be a 8 seater when taking passengers.
Underneath the winches are all ready with new guides welded to the axles for the T-Max 18,500lb winch. Guides on springs to hold up the t-max and Volvo PTO winch cables to be fitted.
The seats have been removed ready to get the wiring done now it will be started this week.
Starting to look complete.
Water tank relocated and redesigned its either now 94liters (24 gallons) or 104 liters (26 gallons) and will be on the front wall of the reaer cabin.
It's first real trip will be 26-28 April when we have a 3 day trip to Cengal Besar (big tree) everything has to work as this track is now really cut up.
New steering wheel to be obtained possibly toyota hilux or similar and after market power steering to be added to the steering column. Steering column etc will be shrouded in alloy to replace the newer plastic which looks tacky on a Volvo.
2 months to go till d-day.
I have to deliver in next 2 weeks fuel gauge and sender, digital tacho, Water, 3 seats and harnesses.
Last edited by geckoadventure on Sun Dec 29, 2013 8:09 pm, edited 2 times in total.
bonefish635
Post by bonefish635 »
The attention to detail at the design stage of this build is hugely impressive. I look forward to each new installment of the story with relish.
Tony
1973 710K
2001 Landcruiser Amazon
2007 Range Rover Vogue (sold)
geckoadventure
New Zealand
bonefish635 wrote:The attention to detail at the design stage of this build is hugely impressive. I look forward to each new installment of the story with relish.
Tony
YEs we are getting there slowly however progress is now rapid I believe the delivery date will be met.
I forgot to mention the overhead console is also designed and will incorporate two radios (VHF and stereo) and a stroage cabinet for wallets fones etc
The left rear under the radiator is to be used for storing recovery straps and the snatch blocks and shackles etc I do not want them in the cabin where they current were stored.
geckoadventure
New Zealand
13 January 2013.
More progress. The new custom toolbox has been built and its holding tray. New 12v battery holder built since we are going from 2 12v batteries back to one really large one.
Wiring is almost completed. Fuse boxes etc all installed in the new center console.
Water tank construction starts later this week.
my next visit is on 24/1/2014 on my way to a wedding in Penang.
GenevaPinz
Post by GenevaPinz »
Thanks for taking the time to post progress on your build.
One thing I didn't notice earlier but prompts a question now: what is a "chungko"? I struggled to google anything that would even remotely put me on the right path... the only thing I know is that it would feel at home next to a shovel and a hi-lift jack... :lol:
Jan
'72 Pinzgauer 710M
geckoadventure
New Zealand
GenevaPinz wrote:Thanks for taking the time to post progress on your build.
Sorry about that try this
http://en.wikipedia.org/wiki/Hoe_%28tool%29
The sceptics would be surprised to see how much dirt a hoe can move compared to a shovel.
GenevaPinz
Thanks, got it :wink:
The local name had me guessing...
Jan
'72 Pinzgauer 710M
geckoadventure
New Zealand
18 jANUARY 2014
Latest progress
all the door handles and latches for the side doors have beeen purchased including the central locking.
Fuses and fuse boxes all connect up also. Power steering units have arrived from the USA and the first one is being fitted to the workshop racing Landrover (V6 Nissan turbo engine it does go rather rapidly lol) and tested so they can sort out any issues and then apply to the Volvo.
Switches and warnign lights to be purchased next week and fitted. They are all going to be bright and approx 1" in diameter each no tiny stuff in this truck.
The gauges finally on their way next tuesday from the USA no way they will make it for the friday run to the workshop in IPOH. So will have to courier them up after sigh.
The new secure toolbox (where the radiator used to be) is built and mounted in its new home.
Priced two new 200AMP batteries this morning from my local supplier 200USD each - sigh.
Next Friday go and buy the rear passenger seats and harneses on my way to the workshop.
I managed to find the big switch I hope to use as a STARTER button - yes its 3" in diameter lol.
Then the kitten knicked the measuring tape
Heinkeljb
Post by Heinkeljb »
Kitten will make better use of the tape measure than you....
Build is going a pace, but then so is your bank balance, (downwards!!!)
How much extra weight have you added to it?
John
geckoadventure
New Zealand
Heinkeljb wrote:Kitten will make better use of the tape measure than you....
John
The kitten has discarded the tape beating up on the 8month older and much bigger kitten is more fun today.
I have no idea of extra weight. it was 2,750kg when I purchased it
1. We removed the rear 440kg and then the rear swingaway tire carrier about 30-35kg so 470kg removed.
2. We added two 44kg batteries
3. We added the rollcage maybe 100kg
4.we readded the steel frame for the alloy skin so roughly 100kg
5. We added two winches M12000 about 55kg and the T-MAX 18500 roughly 66kg
6. The 14B-T is a donk roughly 370kg so possibly 150kg heavier than stock
so at present almost the same weight and we are going alloy wheels soon also another saving of about 120kg
will know when finished and weighed at the weigh station
geckoadventure
New Zealand
24 January 2014
Quiet visit to the workshop on the way to a wedding in Penang.
I handed over the new BIG STARTER button much to his amusement I do wanna use it.
Then it was time for the visit to the truck and to discuss the small progress made.
The new 12v Battery location (under where the radiator used to be) with the 120AMP battery sitting in the location.
Looks naked without the grill
Then it was onto the new tool and spare parts holder.
and then to move it into its new location. A release it being made for the grill to release it from the inside.
Then I wandered around and decided to test the new door and pull down ladder to the roof out. It works so easy to get onto the roof.
ALl the door fittings were viewed and we decided 2 locks per door and the central locking will all fit nicely. The locks will be fitted next week we hope but its Chinese New Year so nothing will be done as the only welder left is CHinese lol so figure 2 weeks before anything happens. The water tank also commences being built next week. I will be delivering the remainig gauges they finally left the USA today according to FEDEX webpage and buying the rear seats and harnesses wednesday as I will be on leave and heading to IPOH for the my CNY family dinner.
So close to getting the rear painted and skinned.
the Door skinning might start next week also.
