Hafi recovery points. Where is best?
- cascade.king
Any ideas? Are there areas that could/should be beefed up?
Re: Hafi recovery points. Where is best?
The most obvious one is the front loop... The welds are on to single skin and the under lying metal is not very thick. I would put another layer on the inside with suitable welding though all the layers.
The two rings at the rear could also do with reinforcement unless you use the tow bar system to make a connection to for recovery.
John
John
