Part needed
Part needed
Post by pinzinator »
Does anyone know where I can acquire this part, possibly in quantity? It is the part at the bottom of the Bosch distributor shaft for the Pinzgauer. Please PM me with info, much appreciated.
Re: Part needed
Probably will need to get it machined up.... doesn't look too difficult. You might contact "compunerdy" and he gets a lot of parts machined up for his business at a good price.
Middlebury_Pinz
Re: Part needed
Post by Middlebury_Pinz »
Have you checked to see if a VW distributor drive off an air cooled type 1 engine will work? It looks identical. I'll check to see if I have one if you want it? Very common and easy to locate if it will work.
Re: Part needed
Thanks everyone for your help! I have received enough replies to get the parts I need.
Re: Part needed
So your having it machined or a VW part works?
Re: Part needed
Several sources including machining. Not sure if the VW part would work, but it should. One guy had 7 for sale, that helped!
