Nutsert Tool
Pinz710m2
Nutsert Tool
Post by Pinz710m2 »
Can anyone tell me which tool is used to install
the nut inserts that Sarah sells from SAV? I'm
replacing my rub rails and bought a few nutserts
to replace some broken ones and Sarah can't tell
me which tool to use with the inserts she sold me.
Locally, it seems no one has ever seen or heard
of a nutsert or nut insert. On the internet there are
about 5 or 6 different tools ranging from $25 to
$500. (SAV doesn't sell the tools)
Has anyone bought the inserts from SAV? And can
you clue me in on which tool to buy?
Thanks.
Re: Nutsert Tool
Did you do a search here for "nutsert"? The topic has been covered a few times, IIRC, and Paul C has done some research on tools I think. It's all been posted previously.
Re: Nutsert Tool
They're sometimes referred to as rivet nuts or rivnuts as well as nutserts.
Here's a thread that should point you in the right direction: viewtopic.php?f=17&t=5138&hilit=rivet+nut
Re: Nutsert Tool
I get all my rivnut equipment from McMaster Carr.
http://www.mcmaster.com/#rivets/=sfufbc
http://www.mcmaster.com/#standard-rivet-nuts/=sfug8t
They also sell the tool.
I made my own.
Pinz710m2
Re: Nutsert Tool
Post by Pinz710m2 »
I did the making of my own tool when I had just 1 rivet (on the safety cage)
and it was the only thing I had to do. When I removed the rails, 4 or 5 of
them were rusted/frozen to the point where the bolt broke off, so I had to drill
the rivet out. Doing it with just a couple nuts and a bolt was a PIA. (My
wrenches were too fat) So I just ordered that wedge shaped tool, since it
was only $20 and I have only 4 or 5 to do. If I had 20, I'd by the fancy long
handled tool. :)
Middlebury_Pinz
Re: Nutsert Tool
Post by Middlebury_Pinz »
Harold,
Give me a call as I have rivnuts and the installation tools.
I also have weld nuts for the side rails.
If you come over on 6/28. I can show you how to install them and help you.
