grease points for drive train
Time to grease the D.T. Where exactly are these points? thanks Zig
Re: grease points for drive train
Three fittings total and don't miss them. I had to replace my shorty shaft,
one U-joint pooped out and took the shaft knuckles with it. Getting a shaft
these days ain't cheap, and you need to get it balanced too. Use a premo
Grease like Lucas.
ron
Grease like Lucas.
ron
You mentioned three grease points for the D.T. I see one on the shaft, where are the other two. Zig
There are two ends of the shaft...check the other one. Sometimes it is necessary to rotate the shaft to find them.
Twin Pinzies
A tip for aligning your zerk(sp?) fittings on the driveshaft for the grease gun:
- Put your transfer case shifter in neutral so you can easily rotate the shaft by hand.
AFTER you chock the wheels!Put your transfer case shifter in neutral
'76 710K
One zerk in each u-joint cross and one on the spline.
George Cameron
Yarnell, AZ
1979 Pinz 710M
Molon Labe
Yarnell, AZ
1979 Pinz 710M
Molon Labe
There is also a grease nipple on the pintle.
HawaiiPinzgauer
These are the PDFs I scanned in from their original German Service Manual. They were front and back, so don't mind the slight discoloration.
- image.jpg (581.04 KiB) Viewed 7141 times
- image.jpg (500.17 KiB) Viewed 7141 times
True. But not exactly part of the drive train, IMHO.berger wrote:There is also a grease nipple on the pintle.
