Battery Switch - replacement specs
ako
Post by ako »
My Pinz came without the battery switch, I guess they took all the expensive elec bits for spare parts before they decommissioned it.
I have holes in the floor behind the drivers seat.
Does anyone have the specs for a replacement unit, such as the maximum volt and amp rating? I would rather buy an equivalent locally rather than pay air freight.
This is the part I mean :
http://www.pinzgauer.com/showdetails.ph ... 111850180/
Mick
150330 Hole in floor.jpg (707.48 KiB) Viewed 5631 times
7111850180 09-01-17 battery switch.jpg (45.68 KiB) Viewed 5631 times
Re: Battery Switch - replacement specs
ako
Post by ako »
Thanks, but I guess you missed this bit :
ako wrote: I would rather buy an equivalent locally rather than pay air freight.
I pay $10 US / pound for getting stuff here.
I went to a truck parts store and asked for the most heavy duty battery isolator they have. I bought a Electro Mecanica Cormar P/N #5000010 which is rated to 250A continuous or 2500A for 5 seconds. Should do the trick.
It was $37 locally, rather than the $49.50 plus freight (and 2 weeks delay) from SAV.
150330 Cormar 500010 battery switch.jpg (881.15 KiB) Viewed 5571 times
David Dunn
Post by David Dunn »
If readily available where you are, Hella has a couple of disconnect switches.
http://www.hellamarine.com/en/products/ ... -switches/
In reality, you don't have to have them. It is a "military " thing to keep batteries from dying from parasitic draws from time of infrequent use or storage
FYI. On the gas Pinz, they were on the negative side of the battery, and on the TDs on the positive.
Do you still have the relay that keeps the circuit closed while the truck is running ? ( It's in case some fool turns the switch off :lol: )
ako
Post by ako »
Hi David.
Yes, the relay is still there. It seems they simply removed the isolator and joined the negative straps together.
Since my new lever is removable, I think I will use it as a 'key' to help prevent some dirt bag try to drive off in my truck.
David Dunn
ako wrote:Hi David.
The old ones were removable too.
That's what most of us do... that average moron sometimes have a problem when the ignition switch isn't in the steering column. :roll: :lol:
sealan
Malaysia
Post by sealan »
ako wrote:My Pinz came without the battery switch, I guess they took all the expensive elec bits for spare parts before they decommissioned it.
Mick
Thus is what i have left from my 718M
Sent from my SM-N9208 using Tapatalk
Curry Pinz - Pinzgauer 718M 6x6 on 33" tyres
CurryLux - Toyota Hilux with SAS on 35" tyres
ako
Post by ako »
How is your parts finding mission going then? :mrgreen:
