So here's my story and my diagnositics to date. Took the Pinz for a drive two Saturdays ago. Ran her around for about 40 minutes. Got home and shut her down. She sat for a few hours and when I went to pull her in the garage, she wouldn't start. She turned over fine and seemed to have plenty of power; but no ignition. So I checked for spark at the plugs and there was spark, but I'm not sure how strong. I've read a bunch of posts on similar topics and the plugs needed changing anyway. So, I've put in new plugs, charged both batteries, and jumped the 4500 rpm limiter. At the point of the jump and after the point of the jump for the limiter I have 24.6 volts. When I get to the coil I only have 10.8 volts. First question, is this normal or is this a sign of the problem? I have a 1975 710M. I have Petronix ignition with the flame thrower coil (30 ohm). I checked the voltage at the white wire on the top of the coil and that is where I get the 10.8 reading. I have also pulled the orange distributor cap, cleaned the rotor and all contact points and re-seated it and snugged it in place.
When I go to start it at first she sounds like she's going to roll. Then I will get a very rough idle where one maybe two cylinders are working. If you give it any gas at all it dies immediately. If I push down on the accelerator before I try and start it then it will take several tries before it will idle up again. Something I also noticed is that the back carburetor is loose between the bottom and middle sections. Could my problem be as simple as tightening the carb? If so, I am assuming I'd need to uninstall it and it tightens from the bottom?
I am not a mechanic but my Pinz has thankfully been teaching me a lot. Through your help and a thorough review of Jim's website I've conquered all of the issues thus far and am hopeful this issue won't beat me!
I live in south Louisiana if the climate makes a difference in your thoughts. It's just crazy she was running perfect. I turned her off and then she won't start up again. Any help you can provide would be much appreciated. I need to get her running but don't want to just dump money on buying parts that won't change my situation. Thanks in advance for your input!
John
