Wanted Haflinger 75KPH Rear Hub Gear Set - not the full set but just the two gears (drive gear and large hub gear) for one rear hub of a Haflinger. The rear hub gears are different to the smaller front hub gears.
Garry
Wanted - Haflinger 75KPH Rear Hub Gear Set
1973 Haflinger AP700
1977 Landrover FC 101
2007 Range Rover Sport TDV6
1957 Landrover 88"
1957 Landrover 88"
Re: Wanted - Haflinger 75KPH Rear Hub Gear Set
Do you know what model(s) of Haflingers came with the 75km/h gears??
I think the Canadian model did but I am not sure of others that may have
I believe it tended to be the later models but they can be retro fitted to all.
1957 Landrover 88"
1957 Landrover 88"
Yes but the key is knowing which models have/had them in order to find you someGarrycol wrote:I believe it tended to be the later models but they can be retro fitted to all.
All the parts one's I have run across have been Pathfinder models and they had the 64km/h hub gears
Thanks but I don't specifically know. Maybe they were not standard but an option - certainly my 73 Series 2 was fitted standard with 70kph gears.
Maybe someone with more knowledge can answer.
Garry
Garry
1957 Landrover 88"
1957 Landrover 88"
