718 Wheel Options
Anything DIESEL driveline, axle, suspension related goes here.
ExpeditionImports
718 Wheel Options
Post by ExpeditionImports »
Hi Guys,
We found these relatively inexpensive wheels from the Dodge Sprinter Vans. The kicker was finding a Lug Bolt that would work with the new wheels as they have a conical seat versus the military ball seat and you cannot use the stock bolts. Anyways, replacement bolts came out of Italy and make it a bolt up conversion. Pictured is with 255/85R16 Maxxus Big Horns.
If anyone is looking for some extra combat wheels drop us a line and we have 15-20 spares!
Scott
Vallejo, California
www.expedition-imports.com
Re: 718 Wheel Options
Do you have a pic of the mil wheels you have there? Wondering about fitting to a G... are they number 34 or 35 on this list? (6.5" or 7")
http://www.rubicon-trail.com/G-Class/wheels/start.html
mopar
Post by mopar »
vince I think these are the mil wheels he has.
1974 712M AKA the Banana
1987 718M Now Sold
1975 Volvo TGB1111 Now Sold
1963 404S Now Sold
ExpeditionImports
Hi Vince,
Mopar is correct, I have the Delta combat wheels which are incredibly heavy and pretty hack in terms of balance. Definitely not the G Hutchinsons.
However, if you are going to be taking gunfire and want to continue to drive, give me a call :)
Scott
Vallejo, California
Ah, I see, well those would look like ass on a G. Guess I'll hold off. ;)
You might consider the stock steel rims from the 2002 to 2006 Sprinter T1N models - they are extremely similar to the #35 on that chart except they are 6.25" wide between the bead lips and have a 75mm ET so it might require some spacers depending on the model of Gwagen you have. Pretty easy to pick up in the USA for $50 each via wrecking yards or craigslist/ebay - just be careful as the 2007 and later models are 6 lug and there is also a dually rim which won't work.
I just did a quick search and found some "premium replacement" rims for sprinters that look like the stock ones but list the ET as being 55mm instead of the normal 75mm - that should make them work well on a 460 Gwagen. Its probably an error though.
http://www.getallparts.com/Dodge-Sprint ... fgodZj4GEA
They are only $78 each.
That would be cool. I need to avoid spacers. I'll have to check into those last ones more.
I actually have a number of these sprinter rims around my shop and can loan you one if that would help... let me know and I can put it in UPS for you.
Hey Vince - There is a thread on the Expedition Portal site of a guy who just bought a Gwagen and is planning on replacing his wheels - so his steel rims might be available. He is in Los Angeles.
http://www.expeditionportal.com/forum/t ... 300GD-w463
Profpinz
Post by Profpinz »
1997, 718 6X6 Pinzgauer
alloffroad
Post by alloffroad »
Hello Together,
I'm Steve from Sydney, I just bought myself a 718K P80 Pinzgauer and I'm new to the Pinzgauer.
Have had 2 Defenders but sold me tourer no replaced by the Pinz.
Just saw this thread and was wondering whether there is a list of wheels which fit from other
brands, I saw the Dodge ones but they will be hard to get here in Australia.
Any help would be greatly appreciated.
Steve
LightRoom_catalouge_New-2.lrcat_-_Adobe_Photoshop_Lightroom_-_Library_2017-05-30_10-25-09.jpeg
LightRoom_catalouge_New-2.lrcat_-_Adobe_Photoshop_Lightroom_-_Library_2017-05-30_10-25-09.jpeg (477.58 KiB) Viewed 17830 times
Pinzgauer 718K P80
Defender 110
www.youtube.com/alloffroadau
The dodge is just a Merceded Sprinter re-branded here in the USA. You need the 5 lug type - so prior to 2007. The sprinters wheels are deep offset / high ET - possibly more than the stock Pinzgauer wheels - and they are only 6 inches wide - so it you want a wider wheel then look at aftermarket alloys for Sprinters - they also seem to have less ET / offset.
Looks like a nice truck! Welcome to the forum!
pinzi
Belgium
Post by pinzi »
Same with ssangyoung rexton rims....ik have them on my 716k
off-road until i die
