Atik G wheels
gunipinzmutt
Atik G wheels
The most common alu rims seen on TDs are Atik from G-wagen. Are there adaptation jobs to be done? Are longer bolts needed?
Pinz: 710 m, 710 ms, 710 k, 712 m fla, 712 k, 716 m, 718 m san, 716 k, 718 rehinbraun
Haflinger: 700, 703
G: 250, 270, 400, 350
Unimog 406
M825, M151 A2, M416
Fiat Panda 141A 4x4
Fresia F18
Haflinger: 700, 703
Unimog 406
M825, M151 A2, M416
Fiat Panda 141A 4x4
Fresia F18
ExpeditionImports
Re: Atik G wheels
We are using a wheel on our tour conversions that is made in the UK for the Sprinter vans. They are relatively inexpensive, look good and are pretty much a bolt on conversion. You will have to change out the wheel studs to a Conical Lugbolt, we found the correct ones in Italy! Retail price in the U.S. is about $175 a wheel and $2 a lug bolt.
Scott
Scott
- img_0587sm5.jpg (77.23 KiB) Viewed 10288 times
Vallejo, California
www.expedition-imports.com
Vallejo, California
Re: Atik G wheels
G Wagen rims fit if you ream out the mounting holes.
I cant recall how much but doable
Porsche ones don't fit as the central hub bore was too small. I just happened to get some Porsche rims to play with one day
Regards
(Project Gimpy 2)
(Project Gimpy 2)
Re: Atik G wheels
I can't recall for sure but aren't the stock steel/military Gwagen wheels the same as the steel TD wheels? Like the green ones on the back of that pic?
Re: Atik G wheels
This is what Magna Steyr/Mercedes are fitting to all the Australian Military G-Wagens.
1997, 718 6X6 Pinzgauer
Re: Atik G wheels
I like the older Euro/rest of the world military, or those newer Canadian mil. version:
- G.jpg (339.6 KiB) Viewed 8927 times
- bf14a51e2d50fef07e8beaec52231a73.jpg (59.99 KiB) Viewed 8927 times
Re: Atik G wheels
The Hutchinson Wheels are my all time favourites (Canadian G) but at 876 euro each (I have seen them available a little cheaper from a few specialist suppliers) I think I'II be waiting for a Tattslotto win before I buy any.
http://www.puch.at/en/spare-parts/acces ... spx?LNG=en
Re: Atik G wheels
Hutchinson's are great but once you go through rocks and bash up the 15 stud threads (x4 = 60) you'll be lucky to get them off without breaking them!
Some Hutchinson's come with the plastic nut caps but not a great solution.
