while trying to sync my carbs i noticed the front carb was no longer getting fuel, i have had this problem before, the accelerator pump came apart inside the carb, i replaced both with new parts from swiss army vehicles, one of which has failed again. is this a common occurrence, is it just poor design? I would hate to have to keep replacing these every year.
would like to know if anyone else has this problem, thanks
-JP
accelerator pump failure?
...and now the fun part.
1981 712 amb
1981 712 amb
Re: accelerator pump failure?
This probably doesn't help much but I've never had one fail. I have had a couple wear somewhat so they no longer pump as well. Try reaching our to Jim LaGuardia for some ideas.
what would be the main job of the accelerator pump in the carb ?? im having trouble on sudden-quick press on the gas pedal the truck DIES! , but accelerates fine on progressive press on the gas pedal .. i was thinking on the carbs pumps
1985 710MS
1985 712MK
1985 712MK
- David Dunn
And you now know 1st hand what the accelerator pump is for.waterdog wrote:what would be the main job of the accelerator pump in the carb ?? im having trouble on sudden-quick press on the gas pedal the truck DIES! , but accelerates fine on progressive press on the gas pedal .. i was thinking on the carbs pumps![]()
During quick acceleration, the carb's suction lags far behind the engines demand for fuel. The pump is a mechanical method to meet that demand
Thanks!!! I thought so,,, :
1985 710MS
1985 712MK
1985 712MK
I think that ethanol eats up the rubber plunger seal. That part is shown here- http://www.pinzgauer.com/showdetails.ph ... 122085120/
You only need the rubber part, I don't see that listed separately. Call them and see if they have just that part. Installation is easy.
