My heater smokes quit a bit, can someone tell me how to adjust the fuel amount or where it should be set at?
Thought I would ask before I start playing with it.
Gas Heater fuel adjustment
- audiocontr
Re: Gas Heater fuel adjustment
Smokes through the exhaust or interior?
Mine always has a lot of exhaust smoke - its diesel
It smokes through the exhaust pipe, but the smoke can then enter.
It should not smoke that much.
Or does it need to be removed and just cleaned and rebuilt?
Does anyone know?
Does anyone know?
I don't know what adjustments are available for the BN4 heater itself; you may have to adjust the fuel pump for less fuel flow. Mine never had even a hint of smoke when it was running, but I've not run it in many years now - I know that it drips gas and I haven't bothered to mess with it.
boeing7873
Did you ever solve the smoke problem? I am dealing with it now. Don't know how to adjust the mixture if it is possible.
JC
JC
Jerome
CRJ Driver
CRJ Driver
boeing7873
I suspect the dosage pump may not be operating correctly.
- 1695199.jpg (157.01 KiB) Viewed 5229 times
Jerome
CRJ Driver
CRJ Driver
Mine put out black smoke I adjusted the screw, from your picture on the far left, turn it out if possible. I reduces the spring tension on the diaphragm. Mine went from black to clean, but my screw was all the way in?? That way when I bought the Rig.
