I was wondering if maybe a Moly-based additive would help in that department - same question for the gearbox & tfr box too ??
Roy
Philip Raymond wrote:
> A. Punt the fan.
First job!
> B. ....try... the quietest and most applicable for on-off road use (IMHO) the Goodyear Wranglers. You'll be amazed at the difference.
I'll check and see if we can get the required size (37" seems about right with no diff changes - good job we're lowering the C of G with the camper shell!) in the UK.
> C. Chances are it will be the rear drive shaft. Balancing technology in the 70’s was not as accurate as today. I’d have it rebalanced and perhaps change over to a newer greasless fitting eliminating the soon to fail rubber boot, and for the cost I’d upgrade the universal joints while I was at it, over all a relatively small investment for a large comfort and functional improvement.
I'm goiing to whip the front and rear-most shafts off and drop them into my local propshaft specialists for an 'update' as you describe. They built the props for my Chevy/Range Rover convertible from scratch and did a lovely job for reasonable money.
I never mess with props after one we made up for a Ford V6 engined Austin Champ we built and raced let go at 60 mph! an underwear-ruining experience, not to be repeated.
Roy
D. I have both run and flat towed C3’s without a front drive shaft without any mechanical ramifications.
