Pulling bottom pulley
rollingpinz
Post by rollingpinz »
I’ve read that some people were able to pull the pulley by hand while others needed to use a puller.
If it comes to that, what kind of puller should I use?
Hugues
Re: Pulling bottom pulley
Post by Hugues »
I've built this extracting tool.
Be careful, cast iron is brittle, avoid sharp hedges, protect with rubber.
I did not break the pulley with the extracting tool but when I was trying to hold it in place to remove the nut.
Carefully mark the position it is mounted in, because there is a keyway in there, it has to go back in the same position and mine was very tight, it was not possible to feel if the key was engaged while tapping it in.
pulley and extractor.jpg (97.43 KiB) Viewed 3097 times
Hugues
From Switzerland
rollingpinz
Thanks for the pic.
Did you use any kind of loc-tite on the bolt?
How did you hold pulley/crank while you torqued the bolt?
Hugues
Post by Hugues »
A bit of green loctite yes.
To remove the nut, I used the starter and a long wrench, pictured here :
https://pinzi-forum.de/viewtopic.php?p=116040#p116040
Hugues
From Switzerland
rollingpinz
I meant how did you hold the pulley/crank while you tightened the bolt?
ChickenPinz
Post by ChickenPinz »
Have you tried with the gearbox in 5th? Does the clutch slip before you reach final torque?
710K
Hugues
Post by Hugues »
ChickenPinz wrote: Sun Apr 20, 2025 10:43 am Have you tried with the gearbox in 5th? Does the clutch slip before you reach final torque?
I think that's what i did, i don't remember any particular trick here
Hugues
From Switzerland
rollingpinz
Oh. Yeah. I forgot to ask. Regular threads(normal directions) on both fan and crank?
Hugues
Post by Hugues »
rollingpinz wrote: Thu Apr 24, 2025 10:10 am Oh. Yeah. I forgot to ask. Regular threads(normal directions) on both fan and crank?
For the crank, I don't remember, but if you look at the picture I linked on the German forum above , you can deduct the thread direction from the position of my wrench and the normal sense of rotation of the engine.
For the fan, I'm not entirely sure, I did it last summer, I think it's a normal thread. Hope someone can confirm.
Hugues
From Switzerland
Both are right-hand thread (standard).
