Fuel pump replacement
ziegler
Post by ziegler »
I will be replacing my fuel pump in a couple of days, is it straight forward or is there anything I should NOT do. Input appreciated.
ChickenPinz
Re: Fuel pump replacement
Post by ChickenPinz »
Super easy. If you read in the service manual there's a procedure for the pushrod clearance, but I didn't find any need to adjust mine when I changed the pump.
While you're at it, be sure to check your hoses and the filter.
Oh, and pay attention to the torque specs so you don't overtighten the pump to the crankcase.
710K
Hotzenplotz
Austria
Post by Hotzenplotz »
for a 1:1 reolacement follow the previous instructions
if you want to save money, you can also go for a VW beetle pump; it fits exactly
and if you want to start immediately, get yourself an electric pump.
select the Hardi 18824 and close the hole in the engine with a piece of steel and two gaskets.
You won't regret it :-)
Albert
Ryan davis13
Post by Ryan davis13 »
Exactly
Stumbler
Post by Stumbler »
You probably already did it by now ... but ... watch that little ceramic or weird brown plastic piece. What do they call that brown plastic-like stuff? Bakelight? lol It's relatively fragile. If you drop it on the floor it will crack or shatter.
