Carburetor
ziegler
Carburetor
Post by ziegler »
There is condensation at the base of the front carb. What is the cause of this and how do I fix it. Thank you very much. Zig
ChickenPinz
Re: Carburetor
Post by ChickenPinz »
Could be normal condensation when the carb temp gets below the dewpoint. Does it do it when the engine is hot, or only when it's cold?
710K
Stumbler
Re: Carburetor
Post by Stumbler »
Need way more detail. At engine temp? Is it condensation or gas? Is it above or below the throttle body? What the weather like during the test? Need a lot more detail to understand. I'm wondering if the throttlebody is loose, but could be normal.
