It's just a hair over 3 inches long. It's a 710K, so no tailgate. But maybe the locks are the same.whitesik wrote: Wed Mar 18, 2026 12:13 pm I am thinking it goes to the rear tailgate lock but tough to know without the size.
The project 710K Begins.
Alaskantinbender
Re: The project 710K Begins.
Regards,
Jim
Jim
Yes, the 710k does have a tail gate or back door and that pin goes into the lock. You would be well served by a parts book. I looked it up for you. I believe it is part 28-05-02.
https://swissarmyvehicles.com/pinzgauer ... q=28-25-02
75 Swiss 710K
W9YG
W9YG
Alaskantinbender
Thank you, I appreciate it.whitesik wrote: Thu Mar 19, 2026 9:37 am Yes, the 710k does have a tail gate or back door and that pin goes into the lock. You would be well served by a parts book. I looked it up for you. I believe it is part 28-05-02.
The parts book is ordered as well.
Regards,
Jim
Jim
Alaskantinbender
Bled the lockers today and got them all working as they should. Nasty, dark, lumpy fluid all gone, replaced with new DOT 3. Replacement rubber elbows/lines on order.
Regards,
Jim
Jim
Alaskantinbender
Looking a little more put together. Mounted 2 ram balls for mounting a camera and my gps map display. I need to invest in an I pod mini to display onx offroad. Another clamp on mount is currently holding my GMRS radio. I added a pic from rebuilding the locker cylinders. Surprisingly, they were still working with all the junk inside.
- IMG_7628[1].JPG (5.28 MiB) Viewed 74 times
- IMG_7630[1].JPG (2.99 MiB) Viewed 74 times
- IMG_7631[1].JPG (3.25 MiB) Viewed 74 times
Regards,
Jim
Jim
ChickenPinz
Here's how I set up the phone holder, dashcam, and GPS mount. And tach.
I find keeping things up higher helps with keeping focus outside.
The GPS mount is a suction cup to the windshield, but also secures on top of the wiper motor.
The phone mount is also suction cup to the windshield, but also with a support bracket to the top of the dashboard assembly.
710K
Alaskantinbender
Looks great. I agree, higher is better. I have had mixed results with suction cups. But I still use them on occasion.ChickenPinz wrote: Sat Mar 28, 2026 8:14 pm Here's how I set up the phone holder, dashcam, and GPS mount. And tach.
Regards,
Jim
Jim
Alaskantinbender
Got the VDO fuel gauge installed and working. I metered in 10 gal of fuel and watched the reading change. I estimate +- 13 to 14 gal of fuel total in the tank at this point. I will fill it up at some point and calibrate the high side. Also removed the old hour meter, not sure if I want an oil temp or just blank it off.
- IMG_7632[1].JPG (3.43 MiB) Viewed 17 times
Regards,
Jim
Jim
