Posted: Wed Feb 11, 2009 11:25 am
Not to argue, just to clarify:
In conclusion, the EMS system works very well as full sequential with Beck's manifold. Until others get Jake's system installed and reviewed we won't have much of a comparison, will we?
Jim Mettler
The EFI system the Jim L. installed has been distributorless from the begining. The EMS computer requires true sequential spark to enable sequential ignition, hence the swap from a two coil wasted spark system to four independent coils. So no real change in ignition (minus the extra "wasted" spark per cylinder), the performance I've noticed is 99% due to the sequential injection.By the way, based on postings, looks like your users who have gone sequential also changed to distributorless ignition at the same time. How do you differentiate between the two with regard to improvements?
Yesterday I had to drive the 712W to work (as it was the only vehicle I had that could get through the 20+ inches of snow without chaining up) and it was 18F. Truck started almost instantly, I set the idle and immediately got out to clear snow and ice. It idled perfectly. This is without any addtional cold start tweaking, just the setup that Jim L. gave me.start up & drive away as low as 10 degrees. Probably spent more time data logging & tuning cold starts than anything
Same here.OEM grade distributorless ignition integrated with the EFI. ... No hotrod MSD boxes, no electrical tape & crimp connectors. Nice, clean factory level engineering
Probably mostly true, I knew from looking at the manifold that it was really only going to work properly with sequential ignition because of it's design. However, it appeared to be designed well for this mode and is (IMHO) extremely well built.So if you saw large benefit from moving to sequential my strong suspicion is that you just leveled out air/fuel flow. Long way around to do that, and you really need to level out airflow first in your plenum design.
FACT? This is just your opinion. Please keep facts seperate from conjecture. If this is how you define "facts", I am less impressed by your statements in general.I can state as fact that the people who would buy our system if released would absolutely not buy your components.
Jim Mettler
