Reborn as Curry-Pinz
Re: Reborn as Curry-Pinz
After a long time,, here's a continuation of the build...
Portals are out to be machined for a different PCD and with studs fitted
- IMG-20160601-WA0011 (2).jpg (112.41 KiB) Viewed 8405 times
Curry Pinz - Pinzgauer 718M 6x6 on 33" tyres
CurryLux - Toyota Hilux with SAS on 35" tyres
Just to share some of the Mods I have decided to run on the Pinz, in consideration of the super hot weather and commonality of parts in our part of the world:-
1) Re-machine new PCDs 139.7 , 6 holes to match most Pickup Trucks PCDs here.
2) Separate Oil Cooler for the ATF away from the radiator
3) Add on Engine Oil Cooler
4) Fit in adapter to use commonly available Toyota Oil Filter.
5) Recore the radiator and remove the built in Transmission Cooler
6) Simplify the piping and routing for the Engine Coolant
7) Junk the old AC and add on a more efficient AC with double blower.
Future mods:-
1) Add in a more modern Fuel filter which has built in Diesel Primer Pump and Water Sensor.
Future mods:-
After some of the mods was completed, the Pinz was released for it's short lived freedom to roam for 2 weeks...
- Pinz After Mods.pdf
- (2.24 MiB) Downloaded 643 times
Anyone knows what do these notation means?
- What are these notations?
- 20160820_164336.jpg (220.71 KiB) Viewed 8362 times
One of the last picts before Pinz goes in for its build and transformation
- Pinz in its ori form
- 20160805_175746 Cropped.jpg (138.44 KiB) Viewed 8361 times
The true Pinzgauer´s
this are copy labels from mark of conformity of break´s, lights, seat belts, seats and glasses. https://de.wikipedia.org/wiki/ECE-Pr%C3%BCfzeichen
Thanks for this, learn something everydayThe true Pinzgauer´s wrote:this are copy labels from mark of conformity of break´s, lights, seat belts, seats and glasses. https://de.wikipedia.org/wiki/ECE-Pr%C3%BCfzeichen
geckoadventure
Hey where's the updates?
Am having trouble resizing the pictures into a smaller size to post...
Need some tips here.
Almost 1,400 picts to choose from...
Promise not to flood the forum
I think the limit is 2Mb
You can just use a free online resizer
Example: http://www.picresize.com/
Never used it but just Google and find one you like
Thanks for the hints... will make some time to reorganize and resize picts for postingsTechMOGogy wrote:I think the limit is 2Mb
