Took the plunge and bought a pair of VisionX headlights. Gezzz, what a difference
Fits perfectly into the bucket and a direct connect to the H4 connector. These are
EXPENSIVE though, but based on comp's with TruckLite it's superior in terms of
lumen output and pattern. As far as I know JW's don't fit. I found a supplier that was
SIGNIFICANTLY less than anywhere else, $600/pair vs. $800 form most
https://www.streetsideauto.com/search.a ... ds=9892443
If you want the Low + High beans on simultaneously you can buy an adapter to do that. Or
re-wire your Headlight switch, relay, and/or H4 connections to ensure Low+Hi are on
simultaneously when the Hi beam switch is on, a wee bit of tinkering but this can be done.
On my 710, there have been many mods, in part by aka SoCal Pinz allowing both Halogen
filaments to be on in the Hi beam position--which made thinks easy for me. But that wasn't
a good idea with Halogen in the first place given all that heat and a short bulb life -- no
issue now with LED's.
The Halo can connect to the running light, if you like halo's. I havn't decided if I like them yet
