Page 2 of 2
Re: Auxillary switch placement- What have you done?
Posted: Mon Nov 27, 2017 10:42 am
Ron, where and how does all the wiring run to all your overhead consoles?
Posted: Mon Nov 27, 2017 11:01 am
by rmel
Two wiring harnesses, one for the heads up which runs along the top of the door jam down the side
then into the rear compartment, sending unit wiring goes through the bulkhead into the engine compartment.
On the passenger side, goes a similar route, catching the ECU for AFR and a Fuel pressure sender in the
engine bay. All good fun, esp. when something fails you you have to debug it
Posted: Mon Nov 27, 2017 12:29 pm
by whitesik
Thanks everyone for answering my questions.
Ron, how does your front overhead console attach to the K body?
Posted: Mon Nov 27, 2017 2:55 pm
by rmel
Sheet metal screws, there are a number of "cavities" over head that can
take a screw and not break through to the open air -- so to speak. Kind'a
works out OK, but it's not designed for easy access. If I were to do this
over, first go Aluminum for reduced weight, then design in a hinged
mounting frame with 1/2 twist locks for easy access and future mods.
Posted: Tue Nov 28, 2017 12:49 am
by GadgetPhreak
Mule did some, not all of the work. The overhead console we fabbed at my place and a buddy finish assembled and rhino lined it.
Posted: Tue Nov 28, 2017 1:29 am
by VinceAtReal4x4s
Nutsert
Posted: Thu Jan 25, 2018 1:14 pm
by Derrickbwg
Trying to keep everything 24v (winch and cb) but I needed a USB plug. Found this Powerwerks 24v 4.2amp plug and installed it as inconspicuously as I could as I'm trying to retain the military look. Good plug that charges galaxy 7 very quickly and was apx. $25.
Posted: Thu Jan 25, 2018 1:21 pm
I like it - where did you find the 24v usb plug?
Posted: Thu Jan 25, 2018 1:37 pm
by Derrickbwg
Posted: Thu Jan 25, 2018 9:39 pm
by VinceAtReal4x4s
Oh man, I wish I'd not seen that. I didn't know they made an OLED volt gauge! On my "must buy, you have no choice" list now.
https://powerwerx.com/blue-sea-1733-ole ... -voltmeter
