WOW, tremendous information. Lots of great ideas and data. It will be very useful as I get more into the project.ChickenPinz wrote: Mon Mar 02, 2026 8:27 pm Here are some of my wiring notes that might help you. Also I've attached a .PDF of the color wiring schematic I've used on my K.
Also, I modified the original taillights to be US standard and support dual-filament bulbs.
I found these https://a.co/d/0ai9mbex to make excellent back-up lights. No holes need be drilled, and you just replace the factory reflectors. Wire in a reverse switch to the transmission with a resistor for reverse lights, and a bypass switch for full power for trail use.
Very much appreciated.
Thanx
