Page 2 of 2
Posted: Sun May 21, 2006 1:11 am
by David Dunn
To be on the safe side, remove the door tops and lay them on a towel to replace the glass..... gravity is less likely to make for a bad day. :wink:
Posted: Thu Jun 01, 2006 6:15 pm
by David Dunn
Received the first shipment of tinted door glasses today... just waiting for that first 710/12 to put them into. :D Have sets for Ms and Ks.
Dave Dunn
Posted: Thu Jun 01, 2006 7:20 pm
by 2012
how much?
Posted: Thu Jun 01, 2006 7:33 pm
by David Dunn
Prices are on the previous page
Posted: Sun Jun 04, 2006 11:20 am
by David Dunn
FORKLIFT- The other windshield removing tool!
Note- No Pinzes were hurt during the filming ..... but maybe I should have had the driver get out beforehand. :roll: :wink:
Posted: Sun Jun 04, 2006 11:28 am
by lindenengineering
Watch out for those forks!!
Patrick at Cold War had a yard man put a set of forks through the side of a Pinz, in short squewerd! Not pretty and a bit expensive to fix.
In that incidence no-one got hurt, just some pride and pocket money!
Dennis
Posted: Sun Jun 04, 2006 1:09 pm
by EvanH
Ok, Dave, if you can install one the same way l will be REALLY impressed!!! :D
-Evan
Posted: Sun Jun 04, 2006 3:10 pm
by MarkPinz
Even with the advanced installation technique :shock:
My K is very happy with the set of Dave's new windows :D
alternate source needed for side window trim piece
Posted: Wed Jun 28, 2006 8:42 pm
by ktmkirk
David, Do you know or someone else on the forum know where I can get that little trim piece that goes on the edge of one of the side windows of the Pinzgauer, I received one from SAV but the other side is backordered. ANy suggestions, I am going to try some Auto trim places but I'm not sure if there is already a repalcement for this peice that is readily available...Kirk
[quote="David Dunn"]To be on the safe side, remove the door tops and lay them on a towel to replace the glass..... gravity is less likely to make for a bad day. :wink:[/quote]
Posted: Wed Jun 28, 2006 9:34 pm
by David Dunn
Kirk
I'm not sure I understand what trim piece you're refering to. The felt tracks? Do you have the part number?
Dave Dunn
Posted: Wed Jun 28, 2006 9:40 pm
by ktmkirk
SAV only had one peice and the other peice is backordered it is called a seal strip ,part# 7111761681 and is the vertical peice that goes on the edge of one of the sliding windows that acts as a seal between the two windows
[quote="David Dunn"]Kirk
Dave Dunn[/quote]
